Removing rotor on Aspen 07
Old Aug 4, 2010 | 08:00 PM
BigboyG206's Avatar
Default Removing rotor on Aspen 07
My left rear started to grind so I went to replace the pads and the rotor, but I could not get the rotor off. The rotor was hitting the caliper adapter/housing. Is there any trick to getting the rotor off without removing the caliper housing?
Also what was strange was the outward pad was completely gone, but he inward pad was in pretty good shape. Has any one run in to this problem?
Old Aug 5, 2010 | 12:18 AM
nope if u want to remove the rotor the caliper holder needs to come off.
Old Aug 5, 2010 | 07:03 PM
15951a\'s Avatar
Check the caliper pins. If they're not corroded, then clean them and reinstall with brake lubricant.
Old Aug 7, 2010 | 02:00 PM
BigboyG206's Avatar
Chrysler Tech,
what is the torque settings? and socket size metric or SAE?
Old Aug 7, 2010 | 08:59 PM
metric no idea 18 19 20 21 don't worry about torque good in tight
nsidle
Jul 9, 2014 09:20 AM
Traci Rattman's Twister Smith
May 19, 2014 08:41 AM
drlisz
Aug 4, 2007 10:28 AM
joeblow
Mar 16, 2007 12:30 AM
MagnumSRT8
Dec 30, 2006 05:42 PM
