Gas pedal restance
Old 07-28-2009, 07:06 PM
kingkohlmn's Avatar
Default Gas pedal Resistance
Hi, new here, did a search here yesterday and got my answer as to why the gas pedal on my 05 Pacifica sticks when trying to depress it. Anyway, why is there carbon build up in the throttle body housing? I thought on air was passing through there. Is there anyway I can prevent this from happening again? Add some type of fuel cleaner?
Thanks Bill
Old 07-28-2009, 09:22 PM
carbon is a by product of gas fumes. clean the throttle body every 30k and U will be fine. Its a service that most dealer offer.
Old 07-29-2009, 12:19 PM
kingkohlmn's Avatar
Is there anything I can add to the fuel to prevent this from happening or do I need to go into the throttle body and clean it like I did on Monday?
Thanks Bill
Old 07-29-2009, 01:39 PM
bizzob223's Avatar
When mine sticks I just take off the air box cover and the throttle body inlet whic lets you see the butterfly valve. Then I just soak it down with a little seafoam and let it sit for about 10 mins and use some paper towels to wipe it clean, just make sure you open the vale to clean behind it and you are good for a while.
Bob
m_tobin
05-10-2011 07:30 PM
mrorange
03-06-2011 08:33 PM
CalOwner
10-03-2009 08:23 PM
doc clock
08-12-2009 07:20 PM
paxmaster2000
11-07-2006 11:53 PM
Quick Reply: Gas pedal restance
