Radiator fans do not come on
Old Jan 2, 2011 | 02:47 PM
jammozzz's Avatar
Default Radiator fans do not come on
Disconnected rattling fan on drivers side while I wait for a new one to arrive, but, neither fan will come on now after driving and idling for quite a while. Temp outside is 19 deg so maybe they won't come on. However, is there something that needs to be reset after disconnecting one fan.
Old Jan 2, 2011 | 04:11 PM
I'd be surprised to see a fan come on at 19 degrees ambient. Any indication of overheating?
Old Jan 2, 2011 | 05:02 PM
jammozzz's Avatar
Default No overheating
Just making noise. I am going to change it this week. Just seemed strange that they wouldn't come on at all seems like they would kick on before at any temp. I let it idle for quite a while, but, thanks I won't worry about it. I have the noisy one disconnected so it won't come apart.
Old Jan 2, 2011 | 11:23 PM
they are series fans both must be connected to work.
Old Jan 3, 2011 | 03:06 PM
jammozzz's Avatar
Default Do both the fans have to be replaced as a unit?
Thanks, makes sense.
Can you just replace the one fan? Or do you have to replace both as I see them sold as a unit?
Old Jan 3, 2011 | 08:28 PM
replace both
Old Jan 3, 2011 | 08:33 PM
jammozzz's Avatar
Thanks, I'll order both. Doesn't look like too big of a project to change.
Old Apr 19, 2011 | 06:40 PM
GreyRock's Avatar
replace both
my 2002 TC Limited's radiator fans will occasionally come on for no known reason, it could be 10 degrees outside and when I know they shouldn't be on they are. they come on when needed for engine cooling and AC operation but like I said they would come on (only occasionally), weird. I have ATC with rear heat/ac. fan relay was replaced with no help, could it be the coolant sensor? it has normal operating temp and never overheats. where is the sensor? I'm sure it's inexpensive if that's it. Thanks!
Old Apr 19, 2011 | 06:59 PM
Djinn-n-Tonic's Avatar
Just a quick question, but I have to ask......
Does this happen with the defroster on????
Doubtful the coolant sensor is bad, because there is no dedicated sensor for the fan. There is an Engine Coolant Temp sensor, which feeds PCM with coolant Data and in turn PCM will activate the relay to turn the fans on....If there were a problem as you describe, It would most definitely either set a C/E light, or cause other driveability issues in another area.
Now...During defroster usage, your A/C compressor is activated to de humidify the incoming Air....When High side pressure exceeds predetermined limit, The fans will operate to avoid Over pressure, and since The condenser and pressurized freon produce their own heat, it will have very little rhyme or reason as compared to outside temps.
Old Apr 20, 2011 | 09:51 AM
GreyRock's Avatar
no, just normal heat operation with no AC or defroster/defogger on.
they run normal (as expected) when AC an/or defroster is activated. I just found it odd that sometimes they would be on after I just exited the highway when we know no cooling fans are needed for only heat or just the cabin "fan" being on, heat or no heat.
Gromit
19
Aug 15, 2013 04:02 PM
dun211
Aug 22, 2008 02:53 PM
gbeach
Jul 1, 2008 11:12 AM
gbeach
Jun 30, 2008 05:01 PM
vlsgmc
Apr 4, 2008 09:26 PM
