Pacifica Thermostat
Follow the Upper Radiator Hose to the Block. There is a Bell housing there that the Hose Connects to. Remove that Bellhousing and the Thermostat is Right Under it.
Hope that helps you out......Im still waiting on someone to at least respond to my question. So for not to impressed with this forum.
That said, welcome. I hope you stick around and learn a few things. Before you know it, you may be giving advice as well. For your TB, clean it well like Chrysler tech said and change the PCV valve for the oil problem. If it still uses oil after this, you may have other problems. If you do a search on this and the Van forum, you will see that some of these cars use oil. My town and county has used 3/4 qt in 1500 miles. OK by Chrysler standards but not mine. I have the original PCV w/ 80k miles and I will be changing it and my TB is dirty too as the wife says the pedal sticks on her as well.
Good luck,
Fixit
06 pacifica blows only cold air accessories pannel has no power on dash to change tem
Welcome to the forum. Next time you have a question, if it's not directly related to an existing thread, it's best to start a new thread rather than trying to wake up and old thread like this one which is seven years old.
The first thing to do in your case would be to check the coolant level. If it's low, you won't get heat out of the heater.
Ironside
06-10-2006 01:42 PM
