tire roar????????
Old May 17, 2008 | 12:20 PM
berk3066's Avatar
Default tire roar????????
just bought an 02 pt ....has new el cheapo tires on it, i thought it had a bit of a tire roar (understandable being el cheapo's) but when i turn to the left it goes away....am i looking at a bigger problem?????
Old May 20, 2008 | 01:49 AM
irdaneel's Avatar
Default RE: tire roar????????
You could be. But tires may only "sing" (politically correct terminology for today's sensitive society when going in a specific direction. Also, misalignment can cause tire noise.
Try putting the wheel in the air and see if you get noise when it spins. (you don't have to have it spinning at freeway speeds to check!) Any similar noise would indicate a different problem than tires.
Old May 20, 2008 | 10:51 AM
moe's Avatar
moe
you need front hub bearings.might as well do both front at the same time.the second one won't be far behind.moe
zipdrive
Jan 16, 2012 01:27 AM
jdsaengine
Jun 15, 2009 04:15 PM
mascu
Jul 17, 2007 07:27 PM
redleopardette
Feb 14, 2006 04:42 PM
Chilli
Jan 19, 2006 12:51 AM
