2003 2.4 no compression
Old 08-25-2014, 08:31 AM
dstevens49's Avatar
Default 2003 2.4 no compression
car was running then one day puff of smoke from exhaust and car died. now it has no compression on all cylinders. timing belt appears to be on the marks. what else could cause this problem
Old 08-25-2014, 08:45 AM
"timing belt appears to be on the marks"
How did you determine that? Your symptoms describe a broken timing belt, probably with valve damage.
Old 08-25-2014, 11:11 PM
dstevens49's Avatar
I took the plastic cover off and looked at the timing marks and also the engine turns over and the cams turn and the no.1 piston is up at the top when the marks line up but no compression
Old 08-26-2014, 02:05 AM
and perform a compression test?
stmiller96
04-26-2012 09:50 PM
lilblkshp
06-23-2011 11:09 PM
chrisso
05-02-2011 01:58 PM
julia giron
04-20-2011 01:18 AM
mrunner13
Cirrus & Breeze
03-15-2008 05:27 PM
Quick Reply: 2003 2.4 no compression
