outside temperature reading
Old 01-01-2015, 09:49 AM
flangar's Avatar
Default outside temperature reading
I have a 2009 Chrysler Sebring Convertible.....love it..but yesterday the outdoor temperature reading on the dash is stuck on 46' F even with the outside temps in the 60's....any ideas and or solutions and cost.....thanks
Old 01-01-2015, 07:54 PM
I would want to start with replacing the ambient air temperature sensor. Not sure about your model but it's usually located behind the front bumper rail. You can look up prices on the web at various sites such as chryslerparts.net and rockauto.com. Some of the dealer sites might have a diagram showing where it's located. Knowing your own skill level and toolbox, you can then decide whether you want to do it yourself or pay to have it done.
p.s. Temperature in the 60's?? That's just not right for New Year's Eve.
Old 05-07-2022, 05:58 AM
Trip93's Avatar
Default 2008 Sebring convertible Ambient temp sensor.
I changed the sensor but it is still not working correctly? Do I need to reset? Possibly the new sensor is bad?any suggestions? Thanks in advance
Old 05-07-2022, 08:36 AM
Check the wiring for broken wires or dirty connections. It's a very low voltage and low current signal so any corrosion or dirt can screw up the signal. You could try a "reset" by disconnecting the battery and grounding the positive (car-not battery) cable to discharge any residual voltage in the car. Not sure that that would help. If none of that works, you might want to have the computer (PCM) looked at. The engine computer needs that signal to set certain parameters so it's more important than just for the readout on the dash. Your performance and mileage can be off if it's not fixed.
Old 05-07-2022, 10:17 AM
Trip93's Avatar
Default Thank you
I’ll give that a shot and let you know.
thanks again!
Old 05-07-2022, 02:31 PM
Trip93's Avatar
Default 2008 sebring
The sensor wire was broke!
I fixed it… seems to be working now😁
Old 05-07-2022, 03:59 PM
H'ray
Old 05-07-2022, 05:30 PM
Trip93's Avatar
H'ray
Thanks for the help!
Z3Roadster
12-10-2015 03:50 PM
SirBuckley
04-13-2014 01:25 PM
robwill
03-15-2011 03:50 PM
Mike213735
09-16-2009 11:55 AM
screamingskull
03-05-2009 12:08 AM
Quick Reply: outside temperature reading
