Valve cover stuck?
Old 06-13-2013, 06:21 PM
loggerbomb's Avatar
Default Valve cover stuck?
Hi all, I have a 95 Cirrus with the 2.5L v6. I am trying to get the rear bank of plugs and plug seals changed but for some reason the rear valve cover seems to be stuck under what I am assuming is the circular shaped belt or timing chain housing on the passenger side of the engine. I have removed all the known screws from the cover itself just stumped on to why the cover wont come out. I dont want to force it out and damage the cover.
Anyone else had this issue before?
Old 12-29-2013, 02:53 PM
David Rovka's Avatar
also have a stuck cover,,, any solution on how to get it off without damaging it?
Old 12-29-2013, 03:04 PM
I guess the answer is to whack it with a two by four.... finally came loose...
Old 01-10-2014, 10:48 PM
Brandon'sJXI's Avatar
Exactly, it just needs a solid whack with (preferably) a rubber mallet. Just be sure to do it at a strategic angle so nothing can be broken.
David Rovka
01-01-2014 09:36 PM
gimpy
10-16-2011 06:45 AM
shaunneff
07-06-2011 09:29 PM
tntandc
03-24-2008 04:46 PM
sumncguy
07-24-2007 09:35 PM
Quick Reply: Valve cover stuck?
