Replacing window regulator system.....
Old Jan 3, 2012 | 08:31 AM
chuckiebtoo's Avatar
Default Replacing window regulator system.....
........on my 02 T&C, driver side. Bought the Dorman unit from Amazon, installed it. Everything perfect except that the window is hanging up when it gets to about 1 inch from fully closed.
Don't know, and can't see or feel, what it's hanging up on. As long as I don't raise it above that 1 inch, it works great. Past that it has hung up 2 times requiring me to loosen the track screws at bottom and top, remove the window from the frame connectors, and jiggle/wiggle/finagle the window loose & start over.
I'm not sure if the Amazon replacement is correct (the frames are a little different than the OEM...as are the white plastic connectors & clips that hold the window to the frame). But, it all fits perfectly except for the hang-up.
Anyone have any familiarity with this?
Thanks in advance,
Chuck
57toplessatlast
Oct 11, 2013 08:26 AM
motley1987
May 25, 2013 08:54 PM
garyw
Apr 17, 2009 07:19 PM
TrickyTree
Aug 31, 2008 05:09 AM
TrickyTree
Aug 31, 2008 05:00 AM
