Urgent help needed please!!
I have a 1999 2.0 LE, and after letting the car stand for two days, my partner found she could not change gears. I felt the pedal and there seems to be little pressure. I am pressuming there is air in the system and needs bleeding, but how do I bleed it? Secondly, what would cause this to suddenly happen?
The vehicle has covered 47,000 miles and has recently had a new clutch.
Please help.
Thank you.
Please help.
Thank you.
Thanks for all your responses, however, I found the problem. The return spring on the clutch pedal had snapped not allowing the pedal to return far enough to push enough fluid to the slave. Thanks anyway, I don't know what I would have without this forum!
kai performance
11
05-18-2010 11:58 AM
