Sponsored by:
Sponsored by:
NO Heat on driver side ?! only - 2010 Chrysler T&C
Old 03-27-2014, 11:39 PM
kg2usa's Avatar
Default NO Heat on driver side ?! only - 2010 Chrysler T&C
Hey, I have problem with heat system on driver side only - no heat at all, passenger side and rear works just great, AC and fans are working but no heat comes out from vent on left front of the car. Already checked coolant level - ok, both heater core hoses are hot ...?!
Help, please....!!!
Old 03-29-2014, 11:30 PM
kg2usa's Avatar
Question any ideas, guys help please....
Old 03-30-2014, 01:55 PM
Raptor 07's Avatar
Sounds like the driver's side zone actuator motor, actuator linkage, the door itself, wiring to it from the control panel or the control panel itself. From reading it appears most of the time the actuator or linkage are the problem. Here's an illustration: http://static.cargurus.com/images/si...8119579792.gif
I'm guesswing you can access them through the center console by removing the radio or HVAC control panel or maybe from underneath. I've read the calibration/test option was deleted on 5th generation vans so the only recourse is to have the dealer scan the system. You and I would have to do it the hard way by accessing the motor and checking power and ground.
Old 04-01-2014, 09:47 AM
kg2usa's Avatar
Thank You so much for Your help
Bobo
03-08-2015 09:24 PM
Stingray
07-24-2011 07:51 PM
castlekin
04-16-2011 05:38 AM
DACouture
01-08-2010 03:36 PM
simonda
01-03-2010 02:44 PM
Quick Reply: NO Heat on driver side ?! only - 2010 Chrysler T&C
