need help with stutter and popping in 2000 voyger
i have a 2000 chysler voyger that stuters between 1 & 2 rpms and sometime when i step on gas a loud popping noise comes from under the hood.i had all plugs and wire changed garage poured in a bottle of stutter gone.there is no lights on the garage said the computer has no errors.plus if i run the ac defrosters it idles rough.any help would be very helpful!!!
RE: need help with stutter and popping in 2000 voyger
I had the same problem. I did have a cracked wire though and the spark was jumping. You should check the terminals on the coil now. You changed the plugs and wires but you may havea terminal that is carboned up from a wire that may have been bad. My #5 wire was cracked and thecorresponding coil terminal was all carboned up.
shahzad
08-21-2013 11:11 AM
mrorange
05-23-2008 06:05 PM
340rules
04-08-2007 12:17 PM
