2004 pacifica
2004 pacifica
Front right hand side turn signal does not work. Replaced bulb, did a continuity check on the light harness. Not sure what I'm supposed to be seeing for readings on power and ground. The Bronx seems to be flashing on and off with the signal when turned on. Any ideas would be appriciated!!!!
Probably easier to check for voltage then continuity. turn the signal on and check from the ground in the socket not the body somewhere and the flasher wire. if nothing ground somewhere else and see. if not look for a plug or something follow the wires and see where they go. I am not sure if they are fused or not look there also.
Hope this helps.
I'll check back.
Mr.Fixit
thank you for replying
I did a continuity check on the light harness itself. Looked good. Did a voltage and ground check after and compared to the left side. The only thing that differed was the ground reading. Showed perfect ground on the side that didn't work and 1.4k on the side that did, without power applied. Did notice that the ground flashed from good to nothing when signal was on, continuity from ground to frame, on the non working side. Which in turn confused the hell out of me. Thinking it grounds back threw the directional?
let me know how ya did.
Mr.Fixit
confused
Did a cotinuity check on the lightharness with it unplugged from the main. Everything looked excellent, no corossion and plugs are in great shape. Checked power between both sides, held consistent at 10.7V. Checked ground with power off and the bad side read 0.00 and the good side read 1.4K. Which leads me to believe it is a ground opperated circuit and that im reading the switch at the other end. 4way and flasher do not work on the bad side. Been looking around online to find a print to confirm what I'm seening or at least point me in the right direction. Unsuccessful as of yet. Got a lead to a free sight but a family of 5 haven't left me time to pursue it lol
Let me know how ya did.
TazExprez
12-07-2023 10:27 AM
dladd@jignet.net
03-15-2007 07:59 PM
