2003 pt won't start
Old Jul 14, 2011 | 02:28 PM
clsals's Avatar
Default 2003 pt won't start
I have a 2003 pt that won't start. I replaced the plugs, wires,coil, crankshaft position sensor, camshaft position sensor. The timing belt was changed a month ago and car ran fine then. It just quit one day. Fuel pressure is 100 to 115 psi. I have spark. In my day fuel and spark did the trick. The oil is ok and oil pressure is fine.
Please help before I burn it!!!!!!!!!!!!!!
Old Jul 14, 2011 | 02:31 PM
are u sure fuel pressure is 110???? that's double what it is suppose to be.
Check for spark any codes in the computer?
Old Jul 15, 2011 | 09:21 AM
clsals's Avatar
Thanks. The problem is the fuel pump! I poured gas into intake and it fired up. The pump runs but obviously its not getting gas. The pressure should be 55 to 65 psi but the reading was acyuially 110?????????????????
nottmtrucker
Dec 1, 2019 02:45 PM
kurt40
Jan 8, 2015 02:00 PM
caolan
Jan 20, 2012 02:35 PM
jasone6789
Jan 7, 2011 11:52 AM
possumfat
Oct 17, 2007 08:35 PM
