camshaft sensor
Old 08-02-2007, 11:30 AM
04300special's Avatar
Default camshaft sensor
Hi I want to know where the camshaft position sensor is located at on my chrysler 300m and is it an easy fix.
Old 08-02-2007, 11:58 AM
Default RE: camshaft sensor
what engine and year
Old 08-02-2007, 12:07 PM
2004 3.5L high output
Old 08-03-2007, 12:09 AM
REMOVAL - 3.5L The camshaft position sensor is installed in the timing belt housing cover above the left camshaft sprocket. [ol][*]Disconnect the negative battery cable.[*]Loosen the upper intake plenum, refer to the Intake System section.[*]Disconnect electrical connector from sensor.[*]Remove camshaft position sensor screw.[*]Pull sensor up out of the timing belt housing cover. [/ol]
Old 08-03-2007, 02:19 PM
Thank you this is very helpful Im going to check it out and let you know how it go. is there a link on the internet that has pictures of this
Old 08-05-2007, 05:55 AM
Thanks for the info again i changethe camshaft sensor but my light is still it has a (p0344) codecamshaft sensor ckt internittent bank. It also have a catalyst efficiency below threshold (p0420), and evap emission control system purge flow fault (p0441). Can u explain what those could be Thank again
Old 08-05-2007, 10:53 AM
420 need a new converter 441 will need some diag done to see whats wrong with the evap system.
and 344 the cam sensor well u never told me u had that code to begine with u assumed that it was the sensor. It still may have been the sensor and the computer just needs to see if the prob is gone by 3 good trips. The light wont go ou though untill all 3 itels listed are taken care of. looks like a shop vist in required for this. Unless u live near Atlanta and I would check it out for u on the side.
Old 08-13-2007, 09:15 PM
i put my car in the shop and my converter is still under warranty so thats getting fixed.they said my strut sway bar was broke and it would cost 500 plus to fix. Is that something i can do myself or a shop have to do it and if so is that a good price?where can i get a manual for my 04 chrysler 300m special.
cdyer11505
20
01-24-2022 12:08 PM
sumncguy
04-17-2012 07:27 AM
manshack_one
12-13-2010 06:59 PM
dcm1971
10-13-2008 12:10 PM
jjmenard
09-06-2007 05:33 PM
Quick Reply: camshaft sensor
