03 Concorde Limited Suspension Clunk
Old Mar 10, 2011 | 09:53 AM
Erbie78's Avatar
Default 03 Concorde Limited Suspension Clunk
Hello all. I recently traded for a 2003 Concorde Limited with just over 80K miles. Everything seems to be great with the car with one exception. It mainly happens with slow turns or travels over short but sharp bumps (ie-in or out of driveway, uneven pavement). I'm assuming it's suspension realted because I don't really know what else it could be. Any help would be greatly appreciated.
Thanks!
Old Mar 10, 2011 | 09:55 AM
Erbie78's Avatar
Oops, forgot to say exactly what it was. I'm getting a clunking noise from either side in the front when going over these bumps.
Old Mar 10, 2011 | 12:59 PM
alexanderc's Avatar
Sounds a bit like strut mounts, but hard to say without seeing the car. I would check all the bushings under the car (i.e. sway bar bushings, control arm, etc) to make sure they aren't collapsed.
Old Mar 10, 2011 | 01:14 PM
Erbie78's Avatar
Thanks for the reply. I would have thought the dealership would have checked something like that out before they sold it, but I'll get a look at them.
Old Mar 10, 2011 | 04:01 PM
Erbie78's Avatar
Okay, please excuse my ignorance on this subject. I know virtually nothing about suspension parts. I took a quick look a little bit ago, and I noticed that the rubber around the bottom of the coil spring is falling apart. Aside from that, I'm not really sure how to tell if the other bushings are bad or not.
Old Mar 10, 2011 | 06:03 PM
gn300's Avatar
Sway bar links make noise as well sounds like time to have a good shop look at it.
Old Mar 10, 2011 | 06:18 PM
DrGadget's Avatar
you beat me to it gn300,I've changed mine several times already,I would sugest that you change 2 at the same time,they're not expensive and it'll save you money in the long run.I got 1 to change now and I'm changing both in the rear.
Old Mar 10, 2011 | 09:12 PM
alexanderc's Avatar
yeah sway bar links are pretty common as well. like gn300 said, take it to a good shop and they can narrow it down.
Old Mar 11, 2011 | 09:00 AM
Erbie78's Avatar
Thanks guys. I'm trying to decide just where to take it now. It's times like this that I wish I was back home.
rtp
May 25, 2024 07:40 PM
steveatpa
Aug 17, 2015 11:13 AM
MiniVanDad
Dec 5, 2012 09:43 PM
BenjaminA
Jan 10, 2012 04:14 PM
Steve Johnson
Feb 5, 2009 03:27 PM
