1995 Chrysler New Yorker 3.5 overheating at idle
Old Mar 14, 2014 | 08:02 AM
rdrodgers's Avatar
Some are double over head cams, some aren't. Sounds like you need to take the timing belt cover off so you can check the timing marks. Which V-6 do you have? Maybe I can find the right timing diagram for you.
Old Mar 14, 2014 | 08:11 AM
rdrodgers's Avatar
Try this link. May have to scroll down to the picture, then click on the picture.
http://repairguide.autozone.com/znet...52802683d9.gif
Old Mar 16, 2014 | 09:36 PM
Herbert Lofton's Avatar
Ok..thanks....When I have time I will....thanks...I'll let u know when I do
Old Mar 17, 2014 | 12:04 PM
95 chrysler's Avatar
I had the same problem . Very hard to fill. You need a special system to properly fill it. Dealer can do it. you need to use mopar fluid too
Old Mar 18, 2014 | 08:11 AM
  #15
rdrodgers's Avatar
A little late and a little wrong on responding to my problem. Mine had a cracked head that caused the coolant to be pushed out.
As for the "Mopar Fluid", mine has Shell brand coolant in it and is cooling fine now. As long as the coolant you use meets the standards set up by the manufacturer, you will be fine.
rdrodgers
Aug 22, 2013 11:39 AM
Alguien
Jun 8, 2011 03:52 AM
Jimbob
Oct 26, 2010 02:13 PM
Alguien
Jul 2, 2009 05:00 AM
Alguien
Jun 27, 2009 04:48 AM
