1997 lhs 3.5 p0306
Old Sep 21, 2018 | 10:29 PM
wtroger's Avatar
Default 1997 lhs 3.5 p0306
As title say p0306 cyl 6 misfire. Only misses for about 15-20 secs and only after setting over night. But it will eventual turn on check engine light. 168,000 miles new plugs and Chrysler wires 6 months ago. Replaced number 6 plug and wire again. Ran wire over intake plenum. Have checked for vacuum leaks get no hint of a leak. Went so far as to plug off the brake vacuum line. Still a miss for a few seconds only on a stone cold start. Did a power clean on the injectors. That did keep the light off for about 3 week. After the initial start up miss it runs perfect. I am pretty much at a loss. Any ideas. If I do have to pull the plenum I will put in new injectors. I do have a new coil pack may try that. Any ideas
Old Sep 22, 2018 | 06:21 AM
REBEL59's Avatar
Sounds like you have #6 cyl. leaking down overnight(not holding system pressure). That will partially flood that cyl. on initial start and the injector should be replaced.
Old Jan 2, 2019 | 12:22 PM
RShoaf's Avatar
Better to test the injector to see if it is leaking before condeming it. Don't replace parts unless you know it is bad.
Live2Fish88
Jul 5, 2016 02:36 PM
davet
May 4, 2014 11:06 PM
97LHS
Jul 5, 2013 10:13 PM
Scotsman4th
Mar 24, 2013 07:50 AM
LeoM
May 23, 2011 03:15 PM
