2000 LHS oil cooler lines
Old Nov 16, 2016 | 08:31 AM
slfalco's Avatar
Default 2000 LHS oil cooler lines
Arghh.. Having just replaced rotten brake lines, the car was taken for NYS inspection, where the tech noticed a bad oil leak, said it was from one of the oil cooler lines. I did not notice this, as there was brake fluid all over the place as it was. I do see aftermarket lines (supply and return) are available, which tells me this is high failure rate item. How involved is it to change those 2 lines? After the brake line experience, I am making no assumptions about how easy anything should be on this vehicle... I also wonder why there needs to be any oil cooler at all, on a non-turbocharged motor, but I guess that was an engineering decision made back then (perhaps slightly better economy, who knows)...
Old Nov 18, 2016 | 04:26 PM
slfalco's Avatar
Well this has gone south.. Impossible to loosen the lower connection at the radiator, decided to bypass instead. I capped off the radiator connections, but I am not sure what to do with the engine sides..
1) The sending unit seems kind of loose, how does it attach to that T fitting thing? What parts would I need to just connect the sending unit directly to the block and eliminate the T fitting?
2) I removed the fitting at the oil pan, seems like a check valve.. What size plug can be used in place of that? I tried to get caps to go onto where the lines would attach at the engine ( the check valve at the pan and the T fitting), but it seems to be metric (M16 fine I think), no one has any plug like that..
Old Nov 19, 2016 | 06:07 AM
FIREM's Avatar
3/8 NPT plug for pan. Remove filter, "T" adapter, thread sending unit into block and done.
T adapter swivels on its mount. If I recall it is 11/16 wrench size flats at the block. Once removed, remove the sending unit and install it back in the block.
Oil cooler lines were discontinued after 02 on"LH" cars.
http://300mclub.org/forums/viewtopic...ooler+deletehe
Old Nov 19, 2016 | 04:06 PM
slfalco's Avatar
Thanks, I ended up capping off the 2 lines by cutting them to about a 1/4 inch protruding from the nut, then inserted a small metal insert in between the line/nut and the fitting, and reassembled with teflon paste. Let it run a good 1/2 hour, no leaks... I am not sure where the metal inserts came from, but they were concave and fit perfectly.. I think they were port plugs that came from an old carb kit from many years ago. I tend to hoard that kind of stuff, never know when you might need it..
Dalton0922
Sep 27, 2014 02:47 PM
joker2cv
Apr 19, 2012 02:55 AM
Rangr90
Mar 1, 2012 03:26 PM
thx569
May 24, 2011 01:18 AM
onecheck
Mar 3, 2011 09:43 AM
