2000 LHS t-stat
Old Mar 9, 2009 | 05:26 PM
miket21's Avatar
Default 2000 LHS t-stat
Hi!! I have a 2000 LHS with a 3.5 motor and need help locating t-stat.
Looks like it is under the air intake and may need to remove i think.
Seems to run hot at times on a 3 hour trip. Temp. will be ok for a while and then gauge will go up to neer the red area and sometimes will go back down to around half way on the gauge.
Old Mar 9, 2009 | 08:23 PM
chk your fans first and the t stat is on the driver side behind the alternator.
Old Mar 10, 2009 | 06:04 PM
miket21's Avatar
Fans working fine, replaced both fan relays just to be sure. Will replace t-stat this weekend.
What type of antifreeze should i use and what is the best way to fill the coolent system and bleed out any air?
Old Mar 10, 2009 | 11:07 PM
I doubt its a t stat if the fans are working and U dont see any leaks more then likely head issues the 3.5 has been known for it.
Old Mar 18, 2009 | 10:37 PM
LHSgirl99's Avatar
I don't mean to scare you...but it does sound like head gasket...have pressure test done. Mine is getting new head gasket as we speak... Mine kept overheating periodically so I replaced t-stat thinking that is what it was...but I went and head pressure test to be safe and glad I did...saved my motor!
2000LHS
Oct 3, 2010 02:16 PM
boosted5speed
Jul 23, 2009 10:23 PM
savone
Dec 14, 2006 08:05 AM
lhsiiisds
Dec 8, 2006 02:00 AM
lhsiiisds
Oct 17, 2006 03:02 PM
