3.2L coolant leak help
Old 02-05-2012, 09:44 PM
ponch37300's Avatar
Default 3.2L coolant leak help
Last Thursday I got home and smelled antifreeze. It was coming from the passanger side of the radiator. So this weekend I replaced the radiator. Put things back together and started the car up. No coolant leaks but the auxilery trans cooler was leaking. I decided to just eliminate the auxilery trans cooler and stick to just the trans cooler built into the radiator, if this becomes an issue I will have to figure out why the auxilery cooler is leaking.
Then I see coolant dripping from the front of the oil pan. I can't see exactly where it is coming from but somewhere on the front of the engine. I was going to order a timing kit with water pump this week since it has 120K on it.
Just trying to do some homework on where exactly this leak might be coming from.
Thanks, Scott
Old 02-05-2012, 11:24 PM
no way to know unless u pressure test it and see where the leaking is coming from under pressure.
Old 02-06-2012, 04:59 AM
ponch37300's Avatar
I did pressure test it but couldn't see where the leak starts. Its somewhere on the front of the engine but not there very front.
Just thought someone might have some experience with a similar leak. Going to start tearing it apart this week to see what I can find.
Old 02-08-2012, 07:46 PM
ponch37300's Avatar
Well the gates timing kit with water pump should be here tomorrow and I also am going to put in a new thermostat and gasket. I read that the thermostate housing is know to leak and fun to get to.
Since I just replaced the radiator it will come out pretty easy and give me some clearance to get to everything.
Any tips on doing a timing kit and water pump and thermostat replacement? I have the balancer puller already and don't think there is any other specialty tools?
Old 02-09-2012, 07:36 PM
TNtech's Avatar
The timing stuff is pretty straightforward. Lay the P/S pump out of the way and you can get to the T-stat from above.
Pop45
01-06-2014 11:35 AM
cfa0703
06-03-2013 09:45 PM
djre49
01-10-2012 09:09 AM
neh218
64
11-28-2011 03:54 PM
92lebaron
12-30-2007 08:57 PM
Quick Reply: 3.2L coolant leak help
