Coolant leak and heater blowing cold air!! HELP, it's -10 degrees outside!
Old Jan 31, 2013 | 03:08 PM
cfa0703's Avatar
Default Coolant leak and heater blowing cold air!! HELP, it's -10 degrees outside!
Bought a 2006 Pacifica in April of 2012, recently I have smelled antifreeze, the fluid was checked and was ok. Then checked again, it was low, so put antifreeze into it, then when driving it after putting antifreeze in, the heater quit working and started blowing out cold air! The antifreeze is not low now, but still blowing cold air. Temp gauge was ok most of the time but did go up one time, then back down. I do have a dealer powertrain warrenty, but I'm not sure if it will cover an issue like this. Is there anything that would perhaps be a recall?
Old Feb 1, 2013 | 05:24 AM
power train will not cover coolant leaks unless the engine itself is leaking U have low coolant pressure test the system see where the leak is.
Old Jun 3, 2013 | 09:45 PM
Kevin Matney's Avatar
Sound like a heater core to me. I had mine smell of AF too put some
Bars Leak Liquid Aluminum Radiator Stop Leak
rowl3y
Feb 27, 2011 10:20 AM
Chrysler300MSpecial
Dec 6, 2009 07:51 PM
glock 40
Apr 30, 2008 10:58 PM
nypacifica
Mar 27, 2008 08:11 AM
johno
Nov 14, 2007 08:49 PM
