99 Concorde - Intermittent Cut-Out / Stalling
Old Feb 9, 2012 | 08:17 AM
MadDog_'s Avatar
Default 99 Concorde - Intermittent Cut-Out / Stalling
I have a 99 Concorde, 2.7L engine, 130K miles.
I've noticed while driving at highway speeds, I'd occasionally have a momentary hesitation, and have had a couple of occasions where the engine would just cut-out (stall) while at idle.
Yesterday on a 100 mile trip, the engine stalled 3 times while at highway speed, just instantly dropping out without warning, a first.
Is there an obvious suspect or place where I should be looking? I can't figure out if it's something with the ignition or fuel supply. If it matters, it's been very wet and damp here the last couple of days, so I don't know if there might be a connection.
Any help would be appreciated. Thanks.
Old Feb 9, 2012 | 08:38 AM
chk the codes in the computer first
Old Feb 9, 2012 | 01:03 PM
MadDog_'s Avatar
I checked the codes, and the only one that shows up is a P1684, which I find puzzling because the battery hasn't been disconnected recently.
Where do I go from here?
Old Mar 4, 2012 | 09:45 AM
MadDog_'s Avatar
Anyone have any clue as to how I'd go about troubleshooting this? I'm still experiencing this problem.
Thank you.
Old Mar 4, 2012 | 07:47 PM
have some one with a better scanner look at it
Old Mar 4, 2012 | 07:52 PM
MadDog_'s Avatar
How do I go about finding a resource with that capability?
Old Mar 4, 2012 | 10:12 PM
most shops will have it
Old Mar 9, 2012 | 05:10 AM
MadDog_'s Avatar
I finally took it in and had a mechanic fix it. Turns out it was the crank sensor, which he said was fairly common. His initial thinking was that it could also have been the cam sensor. I'm not sure how he figured out which one it was, but he did, and I'm damn glad it's fixed.
Old Mar 16, 2012 | 12:18 AM
lovenhate300m's Avatar
Hi MadDog and Kevin, Thanks for sharing your experience. I'm having the same problem. Was the check engine light on when your mechanic looked at it? Did he hook it up the computer? Can you please find out how he figured out it was the crankshaft sensor? Also, how do you know for sure that it's fixed?
Old Mar 16, 2012 | 01:03 AM
MadDog_'s Avatar
My check engine light was NOT on. He hooked it up to the computer and I know he found out it was something with the ignition. I don't know how he was able to ID the crankshaft sensor, but I haven't had a hiccup since, so I consider this SOLVED.
djr9163
May 18, 2021 11:20 AM
skywalker
Jun 1, 2011 12:20 PM
dryle
9
Jan 11, 2010 04:54 AM
djr9163
19
Jul 3, 2009 07:35 AM
johndun20
Dec 15, 2008 11:53 PM
