broke timing belt at 165k
I wanted to know if anyone has replaced a broken timing belt on the 300m 3.5l . Iv got the new belt on but i cant get the cams dead center between there timing marks, does any one have an ideal? Im still not sure if theres a possibility of valve damage when the belt broke, figured i would find out when i fire it up.
no takers hu? i dont blam you, well i have done a compresion check and it was awful, have removed the left valve cover and will inspect the valves tmrw. Do i need to put every thing in tdc before removing the valves?
so after some work i got both heads off and all 24 valves hit pistons, but a gasket set, new valves, and the machine shop seating the valves on the sparkly clean head was only $480.00 and i cleand all the carbon of the pistons, and erg? I have some pics ill post.
so i got the heads on, everything assebled, it runs good but now theres a sound.
when you throttle up theres a whisping sound. the intake gaskets are new everything went on and was tourqed to specs, Im not sure where this sound is comming from besides the passenger side @ the intake area, could it be sucking more air now that everything is internal is clean again? has any one incounterd this after removing there intake manifold?
Tonys02TNC
Dec 29, 2011 09:06 AM
jakster
Jul 14, 2006 02:06 AM
