broke timing belt at 165k
Old Nov 6, 2009 | 11:01 AM
jamnis's Avatar
Exclamation broke timing belt at 165k
I wanted to know if anyone has replaced a broken timing belt on the 300m 3.5l . Iv got the new belt on but i cant get the cams dead center between there timing marks, does any one have an ideal? Im still not sure if theres a possibility of valve damage when the belt broke, figured i would find out when i fire it up.
Old Nov 6, 2009 | 10:09 PM
jamnis's Avatar
Default broken timing belt
no takers hu? i dont blam you, well i have done a compresion check and it was awful, have removed the left valve cover and will inspect the valves tmrw. Do i need to put every thing in tdc before removing the valves?
Old Nov 6, 2009 | 11:58 PM
why cant u get them in the middle? are they between the marks?
U would need to remove the cams inorder to do a compression test the valves are still open.
Old Nov 7, 2009 | 05:21 AM
22chrysler's Avatar
you probably bent the valves. only the gen1 3.5's can take a broken belt without any interference. according to my interference engine guide, the 98+ 3.5's bend valves. looks like you're in for a heap of work
Old Nov 12, 2009 | 06:45 PM
jamnis's Avatar
so after some work i got both heads off and all 24 valves hit pistons, but a gasket set, new valves, and the machine shop seating the valves on the sparkly clean head was only $480.00 and i cleand all the carbon of the pistons, and erg? I have some pics ill post.
Old Nov 15, 2009 | 06:47 PM
jamnis's Avatar
so i got the heads on, everything assebled, it runs good but now theres a sound.
when you throttle up theres a whisping sound. the intake gaskets are new everything went on and was tourqed to specs, Im not sure where this sound is comming from besides the passenger side @ the intake area, could it be sucking more air now that everything is internal is clean again? has any one incounterd this after removing there intake manifold?
Tonys02TNC
Dec 29, 2011 09:06 AM
peabodyn
Jul 30, 2010 10:47 AM
tiewarrior
Sep 25, 2006 12:39 PM
jakster
Jul 14, 2006 02:06 AM
