Concorde 2nd Gen Rack and Pinion Problems
Old Jan 29, 2026 | 01:36 AM
LHSplat77's Avatar
Question Concorde 2nd Gen Rack and Pinion Problems
I am interested in buying a second gen Concorde (1998-2001). I always liked those cars. Anyway, I went to CarProblems.com and it has listed the 2000 Intrepid as one of the worst cars ever built. As you know, it was built on the same platform as the Concorde. Most concerning is the information regarding the steering/rack and pinion issues. Years ago, many LH platform car owners had to replace the rack and pinion in their cars multiple times due to "loose" steering, loss of steering control and constant misalignment issues leading to numerous serious accidents. Apparently, the LH cars have serious steering design flaws that Chrysler refused to ever acknowledge or fix.
Was this a common safety problem for Concorde, Intrepid, LHS and 300M, and if so was a solution/fix ever found? Or is this a common problem for these cars to this day? Thanks in advance!
Old Jan 29, 2026 | 09:10 PM
The main issue was the rack bushings where the tie rods attach to the rack would fail. Pretty easy fix they have kits with better bushings instead of the old rubber ones.
Old Feb 5, 2026 | 01:39 PM
LHSplat77's Avatar
Thank you for the info. Is this a kit I would only buy from a Chrysler dealer? Who makes this kit and do I buy it from a parts store like Autozone?
Old Feb 9, 2026 | 10:30 AM
moog makes better replacements
Old Feb 9, 2026 | 03:05 PM
FIREM's Avatar
It is a wear item concern for Maintenance not a major defect/ design flaw as some would say.
My 2002 with 275000 miles on it, has had 3 or 4 bushing kits installed over the years.
Moog kit with bolts under $25 from Rock Auto does the trick.
www.300Mclub.org has tons of info for your LH series car
Old Feb 14, 2026 | 02:17 AM
LHSplat77's Avatar
Thank you!
Old Feb 14, 2026 | 02:20 AM
LHSplat77's Avatar
Thanks you! Good to know.
burnrub3r
Dec 23, 2021 08:55 AM
Brownd
May 28, 2020 08:17 AM
Bythepond88
Nov 26, 2018 01:19 AM
jerpal25
Aug 14, 2012 05:32 AM
ettienne
Dec 14, 2010 07:33 AM
