HELP! Which Mark is the timing mark?
Old May 25, 2013 | 06:45 PM
Serapium's Avatar
Default HELP! Which Mark is the timing mark?
So I found a youtube video of the original Mastertech introduction to the 2.7L V6 engine and have followed it's procedures (in combination with other info i found on the Internet) to replace the water pump and reinstall the timing chain. Putting it all back together now.
Problem is, I'm not sure which mark on the right side camshaft sprocket it the correct timing mark. In the Mastertech video they demonstrate that the timing mark on that sprocket is the stamped letters RH..... in a couple of images and written tutorials the timing mark is referred to as the small dot (kind of like a dimple) located approximately 135 degrees counter-clockwise from the stamped RH. Which of these is the correct timing mark?
Thanks!
Old May 25, 2013 | 07:19 PM
Serapium's Avatar
Here's a pic of the sprocket in question. The stamped RH in the 2:00 position is what the training video demonstrated to be the timing mark. The small dimple at the 9:00 position is what others have referenced as the timing mark. Which one? Thanks!
Old May 26, 2013 | 01:35 AM
the dot is what aligns up with the plated link on the chain get a manual it will show pics
Old May 27, 2013 | 03:04 PM
Serapium's Avatar
Awesome, thanks!
Blainethemono
Sep 1, 2015 08:30 PM
raynman
Jul 13, 2014 11:19 AM
nicksmith
Sep 25, 2012 07:13 AM
ekonkjack
May 26, 2011 08:07 AM
Hank1946
Jun 26, 2009 10:00 PM
