inner front tie rod bushings
bra dont tell me to get a book.when I already have one. a book can only go so far.. and this site is here to answer questions
The inner tie rod bushings are located at the end of the inner tire rods, bolted to the center of the rack and pinion steering gear. Just about the center of the windshield and down about a 12 to 18 inches. In order to gain access to them, you will need to remove the air intake tubing from the air filter assembly to the the throttle body. If you require alot of room, the strut brace and the wiper module can also be removed. Two large bolts secure the inner tie rods to the block. These bolts are secured with a turn-lock, keeps them from backing out. Remove the outer tie rod at the struts, then the innner at the rack. Next take it inside where you won't freeze. The bushings press in and out. It isn't easy. I usually just replace the inner tie rod due to this. Also remember to lube the adjustment threads, your alignment guy will appreciate you for it.
Good luck,
007.
Good luck,
007.
shootme5150
Aug 30, 2010 04:50 AM
manshack_one
Jan 4, 2010 12:29 PM
