Overheating and leaking antifreeze
Old Mar 17, 2009 | 11:51 AM
trigga_b's Avatar
Default Overheating and leaking antifreeze
Last night I ran into a problem with a 2000 lhs. It started overheating and is leaking antifreeze/water on the front passengers side of the car. it seems to be coming from under the radiator. any ideas? (2000 lhs 3.5L)
Old Mar 17, 2009 | 03:21 PM
dusty-schaffner's Avatar
check hoses and clamps and if u cant find anything run the engine and look for any leak when the thermostat kicks in
Old Mar 18, 2009 | 02:33 AM
trigga_b's Avatar
it leaks while the car is off. is it common for the waterpump or radiatr to fail on these cars?
Old Mar 18, 2009 | 03:53 PM
i dont really know, but if the leak is isolated pretty well towards one side of the car i would check my hoses and radiator for punctures
Old Mar 18, 2009 | 10:19 PM
LHSgirl99's Avatar
Trigga~
I don't mean to scare you...but my 99 LHS was doing the exact same thing. It was my head gasket. For piece of mind have a pressure test done.
Old Mar 20, 2009 | 10:49 AM
trigga_b's Avatar
The car needed oil. But I'm in the works of needing a head gasket replacement, because there's steam like smoke coming from the tail pipe even after the car has warmed up. No disrespect, but I hate chrysler/dodge. They don't use quality parts for longevity.
Old Mar 20, 2009 | 07:31 PM
dodger's Avatar
Well if you don't put oil in it - WHAT do you expect?
BTW I have 340,000 on my 91 Caravan - how's that for LONGEVITY? but I DO occasionally change the oil, but not as much now as before.
And if you want to check the engine - do a compression test... tells U a lot and any home mechanic can do it with a $10-20 tester that will last U a lifetime. I bought one when I was 16, still have it, still use it.
Old Mar 22, 2009 | 09:41 PM
trigga_b's Avatar
i didn't suspect the oil because i didnt hear any ticking and i saw a leak from the radiator and there wasnt any coolant in the resevoir. but wow a head gasket replacement? i'll have to take it to my college and let them do the job for free. oh one more unrelated qiestion, when 1 turn signal bulb blow does this make the rest not work?
Old Mar 23, 2009 | 04:12 PM
it shouldnt, check fuses
Old Mar 24, 2009 | 07:22 PM
LHSgirl99's Avatar
Hi trigga_b~ Mine showed no signs of anything other than when the car was shut off it leaked coolant on passenger side by radiator. which turned out to be a small hole in the radiator...which could very well be your problem too!! But then it would occasionally overheat every now and then. It didn't do it all the time...sporadically. thats what made me think and change t-stat. It helped for about a month then the temp gage started making its way up again. So someone suggested a pressure test and thats the only way I found out it was head gasket. It wasnt very bad...and the motor was saved. I just wanted to give you a heads up and hope that it helps...I don't mean to jump the gun....but if it is hey you can catch it before it really does damage. On second question...I agree with post above...check fuses.
