POWER STEERING NOISE
Old Dec 15, 2007 | 03:45 PM
billbon8's Avatar
Default POWER STEERING NOISE
Hello,
At first start up and when it's cold outside, my Concorde's power steering pump makes a squeaking type noise when the steering wheel is turned. This started 2 months ago. The car is an '01 with 52K miles. Is this noise a precursor to a pump failure? Should I add an aftermarket conditioner that eliminates squeals? I believe that the power steering fluid is ATF +4.The fluid has never been changed, I've never had any leaks and the level has always been good. Any thoughts would be appreciated...
Bill
Old Jan 25, 2008 | 11:04 AM
hildenja's Avatar
Default RE: POWER STEERING NOISE
I had a similar problem a year ago with my 2000 300M. Apparently the power steering fluid wears out. I flushed mine out with four quarts of Amsoil ATF and now it sounds like new.
Old Feb 21, 2008 | 11:31 AM
billbon8's Avatar
Hello,
My noise is abit more of a nuisance now. I found out the PS fluid is the generic stuff (not ATF+4). I sucked out what was in the reservoir (only 6 ounces) and put in new. Basically, unless this site provides some wisdom, I'll just drive it till it breaks....
Bill
Old Feb 21, 2008 | 01:58 PM
moe's Avatar
moe
hey bill you might want to try using ATF4,seen it quite down pumps before.moe
Old Feb 21, 2008 | 07:29 PM
billbon8's Avatar
Hello Moe,
Can you mix ATF+4 with standard power steering fluid? If not, how do I drain the pump and rack? On this car, the rack is about even with the bottom of the pump (not significantly below it). Any info would be appreciated...
BTW Moe where in NJ are you? North, South Central?
Bill
Old Feb 25, 2008 | 10:46 AM
sleeprlegend's Avatar
Lucas makes a great power steering fluid. It conditions your existing fluid and seals, and it also prevents leaks. Buy a small bottle of it, pump out the resivoir, and add the Lucas.
Victor L
Jan 12, 2014 08:38 AM
lotsip81
Jul 30, 2010 11:22 AM
kingdog
Oct 18, 2009 10:21 PM
maynardclan
Mar 28, 2007 02:49 AM
sdlarson
Dec 8, 2006 07:28 PM
