What year engines will work
Old Jul 26, 2019 | 01:39 AM
wtroger's Avatar
Default What year engines will work
History here 1997 LHS older gentleman owns it just trying to help him. It got hot and quit. Later that day he added some coolant started and drove it home have been posting here about the 1997 lhs that has had some problems. Well it is burning coolant white smoke out tail pipe sweet smelling. It is not showing coolant in the oil but it does over heat. He has a 1994 that was wrecked (rear ended). Both are 3.5s will it work without a bunch mods.
What I don’t understand about this is I can put my radiator tester on it and pump it up to 19 lbs and it will not lose pressure. Are these prone to the intake manifold gasket failing. Not sure how it can burn coolant without either a head gasket issue or cracked head or block. Or sucking in to the intake. Any ideas folks.
Old Nov 11, 2019 | 04:48 PM
jamespsnl's Avatar
Looking for a 1994 LHS Exhaust Manifold(s), L and R. Is there another motor or Chrysler vehicle that is the same engine configuration that could be referenced/searched for a matching Exhaust Manifold? Market and/or aftermarket do not lis any for my 94 LHS. Going to a Pick n Pull is so very risky. Any help would be GREATLY appreciated. James / St. Louis.
Old Nov 11, 2019 | 07:43 PM
TChalmsOR's Avatar
Have you checked RockAuto.com ?
turkmando
Jan 19, 2015 08:56 AM
Carbon Fiber
Jan 20, 2014 11:42 AM
treecarp
Oct 2, 2012 09:37 PM
md02167
Jul 18, 2010 07:37 PM
Otis
Mar 3, 2010 08:49 PM
