01 sebring 2.7 weird grinding.
Old Nov 12, 2013 | 08:44 PM
tylersheehy's Avatar
Default 01 sebring 2.7 weird grinding.
So my car just started grinding at 900-1100 rpms. Does it in park sometimes but mainly in drive when I accelerate from stops or things. Also does it when I slow down to a stop sign. It almost sounds like the transmission but the fluid is fine and I just did a service on it. I also did an oil change and and fixed my cooking system not too long ago. I'm lost. I can provide more information if you need. Anyone have any ideas?
Old Nov 12, 2013 | 08:46 PM
If it matters I also have a lifter ticking. Nothing major, tried to fix it with sefoam before the oil change and substituting a quart of oil with rislone but it's still ticking. It did start doing it when I messed with the cooling system. Timing chain has been replaced before I bought the car. Could it be a water pump?
Old Nov 12, 2013 | 09:10 PM
It's almost impossible to diagnose weird noises over the internet. Somebody's "grinding" might be somebody else's "scraping" oe "whirring" or who knows what words somebody might choose to describe a noise. A mechanic's stethoscope is a fairly cheap investment that might help localize the noise.
Old Nov 13, 2013 | 11:40 AM
I was afraid of that answer. I was almost positive it was going to come to that but figured it was worth a shot. Thanks anyway guys!
Old Nov 25, 2013 | 07:05 AM
gb1994's Avatar
Hi; just an idea --did you check the serpentine pulley?
Quick test: Take some lube spray (i.e. MOS2) and spray a bit behind the serpentine while the engine is running. If the grinding disappears then you got the spot. The Mopar part# is 04792410AD; fixing the pulley takes less than 30 minutes.
Good luck
Old Nov 25, 2013 | 08:28 AM
Better replace the belt after spraying lubricant all over it.
Old Nov 26, 2013 | 01:14 AM
gb1994's Avatar
Well, I didn't mean to spray the belt; there is plenty of space between the engine block and the belts to reach the bearing. I should have mentioned that the spray bottle should have a long nozzle comparable to this:
defektivrobot
Nov 5, 2025 08:16 PM
Jauniaux
Nov 25, 2014 03:43 PM
97LXIgirl
Feb 22, 2008 06:30 PM
97ysler
Feb 5, 2007 07:14 PM
andypandy22a
Mar 6, 2006 10:43 PM
