04 Convertible Blower Motor not working
I have an 04 Sebring Convertible that just this am the blower motor stopped working. I've had problems with past Sebrings where the resistor goes out & it works on high, but this is NOTHING. Fuse is ok. Any help would be appreciated!!!
2 things.....
First ...put the control on high, and using a small hammer, or a crescent wrench....Tap the bottom of the motor....If it runs after hitting it, replace it...
Second.....Resistors can burn out AFTER the high speed tap-off also...It IS ABSOLUTELY UNTRUE that a bad resistor will ALWAYS only give you HIGH , That is just simply the more common scenario.
04????? Hmmmm......Its possible you dont have a resistor, but rather a BLOWER MODULE....Which performs the same function, is bolted in the same hole, and looks Identical until you remove it and hold it next to a conventional resistor......The Module will have a large alumminum finned "HEAT SINK" as opposed to the resistors "EPOXY DIPPED" finish.
THEY ARE NOT INTERCHANGEABLE.......
You did check power and ground to the motor didnt you????
jlbenoit
Apr 7, 2013 05:11 PM
rastoma
Jul 7, 2009 07:41 PM
