04 Convertible Blower Motor not working
Old Jan 10, 2011 | 03:28 PM
hammersonranch's Avatar
Default 04 Convertible Blower Motor not working
I have an 04 Sebring Convertible that just this am the blower motor stopped working. I've had problems with past Sebrings where the resistor goes out & it works on high, but this is NOTHING. Fuse is ok. Any help would be appreciated!!!
Old Jan 10, 2011 | 06:25 PM
Djinn-n-Tonic's Avatar
2 things.....
First ...put the control on high, and using a small hammer, or a crescent wrench....Tap the bottom of the motor....If it runs after hitting it, replace it...
Second.....Resistors can burn out AFTER the high speed tap-off also...It IS ABSOLUTELY UNTRUE that a bad resistor will ALWAYS only give you HIGH , That is just simply the more common scenario.
04????? Hmmmm......Its possible you dont have a resistor, but rather a BLOWER MODULE....Which performs the same function, is bolted in the same hole, and looks Identical until you remove it and hold it next to a conventional resistor......The Module will have a large alumminum finned "HEAT SINK" as opposed to the resistors "EPOXY DIPPED" finish.
THEY ARE NOT INTERCHANGEABLE.......
You did check power and ground to the motor didnt you????
Old Jan 10, 2011 | 09:12 PM
Actually no, it just happened today so I haven't had a chance. It was just strange that I parked it in the garage Saturday & it was working, then left for work today & nothing!
jlbenoit
Apr 7, 2013 05:11 PM
rastoma
Jul 7, 2009 07:41 PM
beamond
Jun 2, 2008 09:01 PM
harryvil
Jul 30, 2007 05:38 AM
94 Octane
Nov 10, 2005 11:39 AM
