04 Sebring Limited New Stereo Questions
Old Jan 28, 2017 | 07:20 PM
Joseph Green's Avatar
Default 04 Sebring Limited New Stereo Questions
I just got my hands on a 04 Limited. Everything is working other then the instrument gauge lights (trying to find new one) It has the Infinity sound system which sounds great but I want to replace with a new head unit. Question is with a standard harness is the Infinity amp still going to work and give that extra 150w of power and power the dash speakers? Thanks
Old Jan 29, 2017 | 07:37 PM
You'll have to make sure that whatever you buy will send power to the external amplifier. Then, of course, you'll need an output from your new radio for each of the speakers driven by the amplifier. Best to consult with the supplier of the new equipment.
As for your dash light problems, check here:
Speedometer Repair | Instrument Cluster Repair | Odometer Repair | Mr. Whizard
First make sure that the dimmer control is turned up so that the lights aren't merely dimmed all the way down. Check the owners manual for that.
Old Jan 29, 2017 | 08:16 PM
If I replace the cluster will the mileage transfer/ As in it is stored on the cars computer? Are those AUX inputs that are installed on the CD changer port on the stock stereo easier then replacing the whole stereo?
Old Jan 30, 2017 | 10:26 AM
"If I replace the cluster will the mileage transfer/ As in it is stored on the cars computer?"
Great question to ask at that site I referred you to. They answer questions there. I think the answer is that it's stored in both places and they must agree, but I'm not sure.
"Are those AUX inputs that are installed on the CD changer port on the stock stereo easier then replacing the whole stereo?" Not sure what you're asking here. If your AUX input isn't working, there could be many reasons. Frankly, nobody repairs a stereo any more. They are cheaper to replace than to repair. If you know what you are doing and are good with a soldering iron, have at it.
Old Feb 4, 2017 | 10:07 PM
What are the sizes for the door and back speakers and the dash? Some people say 6x9 but offers not.
Old Feb 6, 2017 | 10:51 PM
Will 6x9 speakers fit the doors? Best Buy said they would but the cover might be a bit off?
Old Feb 7, 2017 | 10:41 AM
Best way to find out is to pop off the door trim panels and measure the existing speakers carefully, including the mounting bolt pattern. If you're going to be changing the speakers you're going to have to know how to get in there anyway, so now's the time to start learning.
A few hints:
There are discussions on the forum here about removing the door trim panels.
Get yourself a set of plastic trim tools. They are worth their weight in gold.
You'll need to remove the paper splash shield. It's held in place by a bead of sealant. With a razor blade and/or an xacto knife you can cut the bead of sealant in half and then just stick it back together on itself when putting the splash shield back.
ctconline
Aug 25, 2013 08:29 PM
uhohspaghettios
Jan 2, 2011 02:59 PM
Profizzle99
Nov 5, 2010 08:49 PM
TedEbear
Oct 24, 2007 09:32 PM
sumncguy
May 9, 2007 09:36 PM
