06 Sebring Horn problem
Old Jan 19, 2012 | 08:59 PM
GregK340's Avatar
Default 06 Sebring Horn problem
Hello, Wife's 06 Sebring Touring 2.7.
Having problem with horn going off at 3-4:00 AM , one long blast 30-40 seconds, only once per night. car doesn't have alarm and horn beep on door lock and unlock is disabled. Seems to be temp. related as it seems to take a temp. drop down to around 20* F or colder to set it off. On colder days it might not go off til it hits 5*F . horn works normally while driving, no problems with horn going off while turning. Changed the relay, didn't help. See lots of posts on the internet of Sebring's with the same or similar problems, but no posts on how they fixed it.
Thanks,
Old Jan 19, 2012 | 09:23 PM
If I had to guess, and it's only a guess, I'd suspect the clockspring. It's a long coiled up wire that allows current to flow to the controls built into the steering wheel. It might be contracting a little in the cold snd shorting out somewhere.
Just a guess.
Old Jan 19, 2012 | 10:16 PM
Horn pads there is power to the horn pad at all times just no ground if it goes off again like that hit the horn pad see if its stops then.
Old Jan 21, 2012 | 07:36 AM
GregK340's Avatar
Thanks for the replies, being such an intermitant,and short event, makes it hard to be there when it happens. But it's suppose to warm up a little next week, so maybe I'll pull the cover off the steering wheel, and see if I can see something. Thanks
Old Jan 21, 2012 | 07:50 AM
its a circuit board u wont be able to see a short in it like that
Old Jan 22, 2012 | 08:18 AM
GregK340's Avatar
Thanks Chrysler Tech., is the a problem you see alot of?
Old Jan 22, 2012 | 08:19 AM
seen it enough time on different makes
Torancis_Chrysler
32
Feb 5, 2016 03:49 PM
stunt101
Mar 13, 2011 07:40 AM
exit9sebring
Jun 26, 2007 04:30 PM
exit9sebring
Apr 11, 2007 01:20 PM
kenny
Dec 23, 2006 12:34 PM
