04 pacifica horn problem
Old Mar 12, 2011 | 06:00 PM
stunt101's Avatar
Default 04 pacifica horn problem
when i put the relay back on and press the horn it gets sstuck then i hit the horn button hard and it goes away but then it blows by it self too can it be the clockspring or a problem in the airbag by the way airbag light does not come on please help.
Old Mar 12, 2011 | 08:32 PM
Djinn-n-Tonic's Avatar
............Horn PAD................
Depending on options..Your horn pad is either bolted in, or on spring clips...
Remove it, and Lube any points where it "RIDES"....That will usually stop it from sticking...If not, the pad and "Switch" assembly must be replaced.....
ALMOST ALWAYS....the pad is available without the airbag, but you will have to reassemble it before putting it back in.
Old Mar 13, 2011 | 01:04 AM
stunt101's Avatar
thanks for the reply if i take the air bag apart to check the horn pad will the airbag blow in my face LOL.
Old Mar 13, 2011 | 07:40 AM
................no...........................Disco nnect the battery and be very careful and attentive to how and where you remove the connectors.
Torancis_Chrysler
32
Feb 5, 2016 03:49 PM
GregK340
Jan 22, 2012 08:19 AM
kartracer20
Mar 26, 2009 08:31 PM
exit9sebring
Jun 26, 2007 04:30 PM
exit9sebring
Apr 11, 2007 01:20 PM
