'07 Brake Lights Not Working
Old Nov 7, 2010 | 08:20 AM
dmosterd's Avatar
Default '07 Brake Lights Not Working
'07 Sebring Touring. Brake lights are not working. Fuse is OK. Brake light switch has power on only one pin. Any help is appreciated.
Old Nov 7, 2010 | 11:30 AM
TNtech's Avatar
Are you using a test light or a meter? Does the center brake light work?
Old Nov 7, 2010 | 12:16 PM
dmosterd's Avatar
Using a meter. Center light does not come on.
Recently had the alternator changed. Could it be the TPIM?
Old Nov 8, 2010 | 12:45 PM
TNtech's Avatar
OK, I would put a brake lamp switch in it. I say this because the TIPM operates the brake lamps on the lower L/R by way of a high side driver(no fuse) after recieving the BS signal over the BUS. The third brake light is a hardwired circuit from the TIPM fuse #3 10A. You have no brake lights at all so the most likely issue is with the switch. There is a far chance it could be the TIPM but having 2 dead circuits at the same time is rare. Just to be sure check the red wire going into the BS, there should be juice there. Press brake pedal and the Green/ White tracer should light up. If not the BS is bad. The wires will be in pins 1 and 2 of the BS connector.
Old Jul 15, 2017 | 02:44 PM
Jennlad's Avatar
Default No brake lights
I have a 2007 chrysler sebring my Centre brake light works but my right and left don't we thought the brake switch so we changed it but no difference. Any ideas on what it could be?
4everrunning
Jun 4, 2019 11:30 AM
murphypat16
Oct 4, 2013 08:39 AM
kendude33
Oct 9, 2010 09:09 PM
mikeg
Sep 30, 2010 08:52 AM
calpacifica
Aug 26, 2007 04:40 PM
