07 sebring dash instrument cluster
Old Apr 30, 2013 | 08:13 PM
crysler's Avatar
Default 07 sebring dash instrument cluster
Hey guys,
I recently bought a 2007 sebring with a dash cluster issue. When I pulled the cluster out the wires in the back were extremely tough to get out. turns out the clips were broken but I had to use one of the wires as a grip to pull it out (trust me I know this was a bad idea). after the cluster came out it turns out the original owner was trying to hide something , maybe a check engine light or something and pulled out the guts for that side. So I put it back together and installed it back in there. Rookie move on my part but I forgot to unhook the negative battery cable and i'm afraid I blew a fuse of sort.
here is what it is doing and not doing
- starts and runs great, it wouldn't go into gear though it acted like I wasn't pushing the brake. I had a shop look at it, they had to lube the switch and unstick it which now it goes into gear,starts, and drives fine.
- The keyless entry is unresponsive. The car will not lock or unlock from the keys buttons but it will from the buttons on the armrest of the car.
- the dash flickers on and off and will not steady out.
- headlights and taillights work.
- radio only turns on and off when the power is pushed on the stereo. If I turn the car off and open the doors the radio stays on until I physically push the button to turn off.
I can only think that I might have blown a fuse, or maybe by not unplugging the battery I shorted something out. I've checked the fuses under the hood and their fine. I know its tough to really guess what might be wrong or what to check but if you guys have any idea id really appreciate it. thanks
rollinsr99
Dec 3, 2014 02:33 PM
Si Preston
Aug 12, 2014 04:05 PM
13walkec
Jan 13, 2014 04:31 PM
landispa
Mar 1, 2013 01:01 PM
2003sebring
Feb 25, 2011 09:00 PM
