1997 Speedometer, odometer intermittant
Old May 20, 2008 | 11:14 AM
mark44004's Avatar
Default 1997 Speedometer, odometer intermittant
I bought a 1997 sebring convertable and when first firing up the ride and after somelengthy travel, the speedometer doest work and the lighted odometer isn't showning. The tach works as well as everything else. After awhile, perhaps after a bump or two, it starts to work. The odometer is wracking up the miles which is fine. Is there a TSB about some connectors or do I need to replace the cluster? Thanks.
Old May 20, 2008 | 11:32 AM
moe's Avatar
moe
Default RE: 1997 Speedometer, odometer intermittant
hey bud, you might want to check on a loose connector behind the cluster itself.see if you can narrow it down by moving the harness behind the cluster,hers what your dealing with.good luck.moe
INSTRUMENT CLUSTER- C2
CAV
CIRCUIT
FUNCTION
L39 18LB
FOG LAMP SIWTCH OUTPUT
E2 18OR/YL
PANEL LAMPS DRIVER GROUND
11
Z1 18BK/OR
GROUND
12
G6 20GY
OIL PRESSURE SWITCH SENSE
13
G19 20LG/OR
ABS WARNING LAMP DRIVER
L61 18LG/TN
LEFT TURN SIGNAL
D2 20WT/BK (WITH TRAVELER)
TRAVELER CCD BUS (-)
D1 20VT (WITH TRAVELER)
TRAVELER CCD BUS (+)
F18 20LG/BK
FUSED IGNITION SIWTCH OUTPUT (RUN/START)
G9 22GY/DB
RED BRAKE WARNING LAMP DRIVER
D2 20WT/DB
CCD BUS (-)
D1 20VT/BR
CCD BUS (+)
9
INSTRUMENT CLUSTER -C1
CAV
CIRCUIT
FUNCTION
L60 18TN/BR
RIGHT TURN SIGNAL
12
13
G78 20TN/BK
TRUNK AJAR SWITCH SENSE
F11 18RD/VT
FUSED IGNITION SWITCH OUPTU (OFF/RUN/START)
Z2 18BK/LG
GROUND
F33 20PK/RD
FUSED B(+)
G69 20BK/OR (WITH VTSS)
VTSS INDICATOR LAMP DRIVER
G29 20BK/TN
WASHER FLUID SWITCH SENSE
9
Old May 20, 2008 | 11:41 AM
mark44004's Avatar
thanx for the info.
Old May 20, 2008 | 11:52 AM
moe's Avatar
moe
cool!
Old May 20, 2008 | 02:31 PM
printed circuit board in the cluster is bad.
Old May 22, 2008 | 07:18 PM
irdaneel's Avatar
If you play with it long enough, and have the patience and proper electronic tools, you may find a cold solder joint in the PC board, or wiring connectors.
Old May 25, 2008 | 04:47 PM
seawind3000's Avatar
You might want to check here, they fixed my "indglo" that the dealer said would be $1200 for a new dash.
http://www.mrwhizard.com/services2.cfm#Start
Mike
deerhunter
Oct 26, 2015 01:47 PM
PTfred33
Oct 29, 2009 07:30 AM
mjhart34
May 7, 2009 04:34 PM
doogstrum
May 5, 2007 01:05 AM
doogstrum
