1999 Chrysler Sebring Convertible turns over but doesnt start
I have found the problem to be the ignition coil which resides inside the distributor. They say it is a non serviceable part but that is incorrect. You can purchase from any major parts store. Prices range from $35 (Pep boys online) to $135 (NAPA brick and mortar). Here is a pic: https://images.oreillyauto.com/parts...99_primary.jpg
I have gone through this 3 times now on my 99 jxi - believe me I know the frustration. Remember there are only 2 conditions which will cause the ASD: improper camshaft signal to the PCM OR improper crankshaft signal to the PCM. One of those is inside the distributor - but that isn't the problem. The coil is the actual problem. You can check primary coil resistance on the 2 pin connector - it should be between .6 - .8 ohm. Also check the secondary coil resistance by checking the resistance between the high voltage terminal and connector terminal 11 of the 2 pin connector. Value should be 12 - 18 k Ohm
I will be addressing this issue with my car soon and I'm interested in replacing just the coil as you mentioned was serviceable. The link to the picture you left leads no where for me. Do you have more information on the specific coil? Another picture or part number maybe? Or can i just ask for a coil for this particular distributor?
Thank you!
ulyman
Aug 25, 2015 03:06 PM
johnstein7394
Jan 13, 2014 09:09 PM
GandJautomotive
Dec 30, 2013 03:30 PM
roykaren
Jul 15, 2010 08:18 PM
