1999 Sebring Conv - no electrical power
Old Dec 13, 2011 | 09:20 AM
mlrubin's Avatar
Default 1999 Sebring Conv - no electrical power
Probably a fuse, but before I try and pull everyone of them thought I would get some advice.
Ran fine on Friday. Went to start it on Monday and nothing. No horn, now power to anything.
Battery is less than one year old, and I could not charge it with a battery charger.
Any suggestions on if this is a fuse or relay. Or should I just get it towed to a mechanic and let him mess with it....
Old Dec 13, 2011 | 12:18 PM
dont pull fuses use a volt meter or test light
Old Dec 13, 2011 | 07:28 PM
You might have left the lights on and killed the battery. You might have corrosion right at the battery or in one of the connections to the battery. First check the battery voltage, then check for voltage from the battery to the fuse boxes and go from there.
bamabeauty81
Jan 6, 2012 05:13 PM
aifam55
Jan 22, 2011 05:49 PM
cstingray
Sep 21, 2009 09:10 PM
badatbeach
Jun 23, 2008 09:54 AM
