2.7: Coolant boiling, fans off, Tē gauge in "normal". What happens??. Help!
Old Aug 29, 2012 | 11:51 AM
Denis.V's Avatar
Cool 2.7: Coolant boiling, fans off, Tē gauge in "normal". What happens??. Help!
Hi,
My 2003 2.7 sebring was boiling 3 months ago. Replaced radiator cap and problem finished. Then, 3 weeks starts boiling again. replaced plastic upper water outlet (leaking too) with temperature sensor included ("Dorman" product made in China), and I replaced the failed thermostat too. Problem finished. Yesterday, boiling started again.
Coolant is boiling with temperature gauge at medium position, but fans don't work.
When I connect the air condit. fans work O.K.
When running car with max. heater, coolant don't boils and no problem.
What could be my failure?.
Anny ideas?. Please help. This car is used for my children transportation to school.
Thanks in advance,
Denis V.
Old Aug 30, 2012 | 09:39 AM
make sure fans come on make sure there is coolant all the way to the top of the coolant jug make sure there is no air bubbles in the system.
Old Aug 30, 2012 | 04:15 PM
Also make sure you have the proper mix of water and antifreeze. Too much water or too much antifreeze will cause it to boil at a lower temperature.
If you have a blown head gasket, it could cause boiling, or if you have installed the thermostat backwards, it could overheat rapidly.
Old Sep 4, 2012 | 08:26 PM
DaleCarol's Avatar
manan
Aug 9, 2019 05:22 PM
HowieF16
Oct 13, 2014 03:49 PM
jayroc7113
Apr 3, 2014 04:34 PM
Lanvale
Oct 12, 2011 05:21 PM
tycho
Jan 1, 2011 07:27 AM
