2.7 no start
Old Jun 16, 2016 | 10:37 AM
dstevens49's Avatar
Default 2.7 no start
2002 2.7 sebring no start. have fuel,power to injectors,power to coils anyone with idea what to look for thank you
Old Jun 16, 2016 | 12:16 PM
jopizz's Avatar
Does it make any noise when you crank it. I've seen quite a few 2.7's throw timing chains due to hydraulic tensioner failure. It may have also jumped a few sprockets. If you have spark and fuel it sounds like it may be a timing issue.
John
Old Jun 16, 2016 | 05:01 PM
Power to coils doesn't mean you have spark. The spark happens when the power to the coil is interrupted, the magnetic field in the coil collapses and a high voltage is induced in the secondary side of the coil, causing a spark.
You might want to check your compression to rule out timing failure.
Old Jun 16, 2016 | 05:44 PM
jopizz's Avatar
That's a good point. I would pull one of the spark plug tubes, plug in an old spark plug, lay it on the block and crank the engine to see if you really have spark.
John
Old Jun 16, 2016 | 09:31 PM
thirdly did this all of a sudden happen or was something else done and now it wont start?
Old Jun 17, 2016 | 10:36 AM
dstevens49's Avatar
Default no spark
John
no spark to plug
Old Jun 17, 2016 | 03:49 PM
Codes?
Old Jun 20, 2016 | 10:19 AM
dstevens49's Avatar
Codes?
No codes dont know history helping out a friend just bought car
Old Jun 20, 2016 | 02:40 PM
If there's no spark, there's a high probability of a fault code somewhere in there. You can check for codes with either the "key dance" (key on-off-on-off-on; codes will appear in the odometer space) or get a code reader attached to the car and pull them that way. You may be able to rent/borrow a code reader from an auto parts store.
There are hundreds of parts involved in starting a car. There's no point in just guessing which one is bad. The computer is designed to monitor many, if not most of those parts and report the existence of faulty parts. That's where you need to begin.
Nfamous60
Dec 2, 2015 09:40 PM
jbda
Cirrus & Breeze
Apr 1, 2013 11:09 AM
