2001 Sebring convertible autostick not shifting-Please help guys
Old Nov 12, 2009 | 09:14 PM
01goldsebring's Avatar
Default 2001 Sebring convertible autostick not shifting-Please help guys
2001 Sebring Convertible autostick
95k miles
I can put the car into park, reverse, neutral, and drive and I see each one will be highlighted as I select it. When I go down to autostick, 1,2,3,4 will not get highlighted.
When the car is in drive, the car goes and the RPMs just keep climbing as I accelerate and the car doesnt shift.
The tranny shop scanned the car and it read - PO340 No cam signal at PCM and PO700 transmission fault present.
What can this be? I need to get my car shifting again, Thanks!
Old Nov 14, 2009 | 10:05 PM
You might want to try a different transmission shop that knows what it's doing. The P0700 code is a general fault code that indicates there are problems that can be read with the proper equipment. It might be necessary to run a pressure test, again, proper equipment and knowledge are necessary. Be sure your fluid is up and clean before you run additional tests.
monchito_yeyeye
Nov 21, 2012 09:09 PM
M1Ark
Jul 24, 2009 06:34 AM
Capa
Jun 18, 2007 11:06 PM
JVieira
Mar 12, 2007 01:46 PM
JVieira
