2001 Sebring - Salvage the entire soft top ?
Old 01-28-2018, 03:21 PM
bdomi49's Avatar
Default 2001 Sebring - Salvage the entire soft top ?
Hi, I have a 2001's Chrysler Sebring 2.7 V6 convertible.
I would like to know how to salvage a soft top (frame + soft top) on a scrap car ?
Can I unscrew only 2 large screws at the base of the frame? (see the image explained below)
Thank you for your answers.
Old 01-28-2018, 08:46 PM
You will have to disconnect the hydraulic lift mechanism and detach the bottom rear of the top (the "tack rail" in the drawing.)
Old 02-01-2018, 01:29 PM
bdomi49's Avatar
Ok, Finally I will not recover everything but only the rear window.
Can the rear window be easily removed from a soft top ?
Thanks.
Old 02-02-2018, 10:18 AM
If by "easily" you mean "with a jackknife" then I suppose the answer is yes. The hard part comes when you try to install it in your car.
Old 02-02-2018, 10:29 AM
bdomi49's Avatar
Of course, the installation will be complicated.
Would you know how to go about replacing the glass ?
Thanks for your help.
Old 02-02-2018, 01:25 PM
02 Limited Conv
05-19-2016 05:08 PM
Mark
12-10-2014 09:13 AM
Laredo Scuba Diver
11-27-2012 04:31 PM
Hawwk11
11-24-2009 07:34 PM
05-10-2006 05:36 PM
Quick Reply: 2001 Sebring - Salvage the entire soft top ?
