2001 sebring sedan front wheel studs
Old Jan 7, 2009 | 08:02 PM
jamgratz's Avatar
Default 2001 sebring sedan front wheel studs
how do I replace the front wheel studs on my 01 sebring sedan? I have the calipar off, I got the axil nut off, but can't seem to get to where I can replace the studs.
Old Jan 7, 2009 | 08:25 PM
Default RE: 2001 sebring sedan front wheel studs
You need to pull the steering knuckle off. That's the part that holds the hub and turns to steer the car. To do that, you need some special tools to separate the ball joints that hold it on. Then you'll pull the knuckle off the drive axle.With the drive axle out of the way, you will be able to get to the bolts on the back side of it that hold the hub to theknuckle. You can unbolt the hub and press out the studs from that point.
I would suggest this: Buy or borrow from the library a Haynes manual for your Sebring. Read through the chapter on suspension and steering as it pertains to removal of the steering knuckle. Then you can decide whether you want to invest in the tools and spend the time and effort or whether you feel you are better off paying someone to do it.
Good luck. Let us know how it comes out.
Old Jan 8, 2009 | 08:03 AM
Cordoba Man's Avatar
Pickle forks are cheap and easy to pop out ball joints from the knuckle, but they almost always wreak the seal on the ball joint. A press is more money, but worth every penny. What you will spend on the tool is about what you will save in labour if you do it yourself, and then the tool is 'free', and you will have it next time.
Old Jan 8, 2009 | 12:29 PM
Pickle forks are fine if you are replacing the ball joint. Like you say, they can be counted on to destroy the rubber boot. If you want to re-use the joint, you need a proper puller.
Old Jan 9, 2009 | 10:15 AM
Worth every penny.
Old Jan 9, 2009 | 03:05 PM
Rick99's Avatar
Usually you can remove the wheel studs without removing the knuckle or hub. On my 97, there's a cutout area toward the front of the knuckle rotate the stud to that location and remove it. Yours most likely has a similar location.
I just replaced a few studs on my Durango and there was a place you can pull them out. The factory manual says not to bang them out with a hammer (like most people do), but to press them out with a special tool. I couldn't find the specialtool all the guys at the parts places said everyone just bangs them out, so I used a hammer as carefully as I could.
Old Jan 9, 2009 | 06:45 PM
Hammering on the studs is hammering on the bearing.
ikester
Oct 5, 2010 02:36 PM
dws
K-Cars
Jul 19, 2008 01:17 PM
NisCAPE
Jun 22, 2008 04:24 AM
wardncr
Nov 16, 2007 01:17 PM
