2002 Chrysler Sebring Convertible
Old Jan 23, 2020 | 05:09 PM
Alicia Kerner's Avatar
Default 2002 Chrysler Sebring Convertible
Hi my signals and hazards stopped working. After reading something similar in the forum here I checked the fuse, changed the combination flasher (the green box) AND changed out the signal arm (switch?) and my signals and hazards still WON’T WORK. $100 down the drain to fix something that still isn’t working. Any help would be appreciated!!! TYIA!!!
Old Jan 23, 2020 | 08:49 PM
Check all the bulbs. Check the ground wires.
Old Jan 24, 2020 | 12:44 AM
thank you I’ll try that next. Where are the ground wires located and how can u tell if they are bad??? I find it so weird that the wipers work n the lights but not the signals. Lol driving me crazy
Old Jan 24, 2020 | 09:53 AM
Leading from each light fixture will be a number of wires, one of which is black. That's the ground wire. Follow it until you find a place where the black wire is screwed to the metal of the car. Loosen the screw a little, wiggle the connection to break up any corrosion, then re-tighten the screw.
You should have checked the bulbs first. When in doubt about any repair, always do the cheapest and easiest things first. No point in spending a hundred dollars if it could be a five dollar repair.
cwilson
Dec 7, 2016 04:25 PM
powaka
Dec 6, 2015 08:32 PM
Gma891135
Dec 1, 2014 09:21 PM
blyndside
Jun 5, 2013 01:02 AM
theajes
Jun 13, 2011 10:22 AM
