2003 Chrysler Sebring Transmission Problems
Old Aug 11, 2009 | 01:38 PM
casiaw16's Avatar
Angry 2003 Chrysler Sebring Transmission Problems
I have eight (8) MIL codes on my transmission.
1. PO700- TRANSMISSION CONTROL SYSTEM MALFUNCTION
2. PO841- TRANS L/R PRESSURE SWITCH CHECK FAILURE
(MIL CODE 036)
3. PO992- 2-4/OD PRESSURE SWITCH TEST FAILURE
(MIL CODE 051)
4. PO994- LOSS HYDRAULIC PUMP PRIME
(MIL CODE 053)
5. PO733- 3RD GEAR INCORRECT RATIO
( MIL CODE 083)
6. PO732- SECOND GEAR INCORRECT RATIO
(MIL CODE 082)
7. PO1790- FAULT AFTER SHIFT
(MIL COD 054)
8. PO846- 2-4 SIGNAL CHANGE
(MIL CODE 034)
ANY HELP WILL BE GREATLY APPRECIATED. 2.4 DOHC. TRANNY TAKES TIME TO ENGAGE AND TO SHIFT.
Old Aug 11, 2009 | 09:30 PM
Have you checked your fluid level? When was the last time it was changed?
If the problem isn't fluid related, the next area of attack would be to replace the solenoid pack. Search the forums for a discussion on how to do that. If you're reasonsbly handy you can do that. No guarantees there, but if you search the web you can find a solenoid pack for about 50 bucks. If that doesn't do it, it may be time for AAMCO.
Edward Smalley
Jul 5, 2015 09:39 AM
boyan
Aug 25, 2014 02:41 AM
JR13
Jan 27, 2011 09:35 AM
r.tieleman
Mar 23, 2007 09:04 PM
beccacoll
Feb 21, 2007 12:07 AM
