2004 Chrysler Sebring 2.7 overheating issues
Old Sep 20, 2024 | 07:25 PM
tmorales509's Avatar
Default 2004 Chrysler Sebring 2.7 overheating issues
So started having an overheating issue, replaced the thermostat first, still overheated, next replaced the radiator, still overheats. I've tried bleeding the air more than a few times and a few different ways with no luck. When it starts overheating the fluid will push up and flow out from the reservoir and through the cap. No white stuff in oil, no smoke, no leaks that I can see, other than overheating no other symptoms. Any suggestions?
Old Sep 20, 2024 | 08:30 PM
block test or use a funnel and look for bubbles when the engine gets to 210 or above if you see bubbles you have warped heads.
PT partner
Apr 25, 2024 09:57 PM
ricksaldana
Sep 11, 2022 07:52 PM
npereza5
Sep 7, 2021 08:58 PM
dstevens49
Feb 2, 2016 04:01 PM
moving on
Jul 19, 2010 10:33 PM
